skratch
I'm replacing the left rear brake cylinder on my 58 CJ5. Noticed the brake shoes have one long pad, the other is
quite a bit shorter. Just curious why that is.
The short lining always goes toward the front. The wheel cylinder pushes the front shoe out, then it grabs the rotating drum and tries to turn with it. That pushes on the star wheel adjuster to push the bottom of the rear shoe into the drum. The the wheel cylinder pushes the top of the rear shoe into the drum. Both forces act on the rear shoe, (the longer lining) so they call it a "duo-servo" drum brake.
As a result, the rear shoe has a longer lining surface than the short shoe because it does 75 percent of the braking.
Guys,
Please check this post out to determine whether your brakes are Lockheed or Bendix type, as the "long shoe position" will be leading or trailing depending on the system:
https://www.oldwillysforum.com/forum/index.php?threads/brake-shoe-install.8036/#post-817.
...and then look through the rest of that terrific thread!
Here's a picture from my 1948 pickup that I just completed a couple of days ago...
...showing the front left brake assembly. These are Lockheed style brakes and others might also want to know this about Lockheed style brakes. Hydraulic pressure expands the wheel cylinder cups, which push the shoes against the drum. The shoes are NOT self-energizing. The Lockheed system is a front/rear shoe design with the bottom pivot for each shoe anchored to the backing plate. This design requires more pedal pressure to stop than self-energizing brakes since they rely solely on hydraulic pressure. The front shoes (primary) do most of the stopping and normally use a longer friction band. The rear shoes (secondary) normally use a shorter friction band. That might help some of you who think the shoes were installed backward as they would be if these were a Bendix style. Long shoe goes toward the front. As I said this is for my '48 but I would guess it's the same for your '53.
I hope that helps and good luck with your truck.
Thomas
Crap keep forgetting about pre self energized brakes.Guys,
John,
The pins and springs make me think "Bendix"...
Do they have star wheel adjusters bridging the bottom of the shoes?
The Lockheed brakes adjust using concentric cams, and the bottom of the shoes rest on a stationary pivot post.
On Lockheeds, you'll also see those adjusting cams at 3 and 9 o'clock in the image posted by Thomas/BB767.
(Swapping in Bendix for the Lockheeds is an extremely popular brake upgrade.)
Brake shoes with different lining lengths are made that way to equalize the wear... No sense putting a long lining on a brake
shoe that will out last the other... So, to equalize the wear... And save a penny here and there...
Now, somebody explain to me why truck air brakes with S cams don't use a long/short shoe setup........
Sure sounds like Lockheed. The pin type shoe retainers are unusual...
I do have a partial answer... Large trucks need all the holding power they can find when parked on hills with a load... The the braking/holding power on trucks with S cam brakes is equal, whether they are parked uphill or down hill..Brake shoes with different lining lengths are made that way to equalize the wear... No sense putting a long lining on a brake
i just got done replacing my drum rear brakes on my 66 nova.....i watched an 8 minute youtube video....i was out there for 2 and a half hours! on one wheel! but now i know how to do it and lord help me the brakes workThis copied from the link Joe B provided along with my comment.
That looks close to mine but mine is on a 58 CJ5, except mine has the springs & pin where yours has the tabs,
and the upper spring goes in the round holes at each end. And wouldn't you know it I just finished mine, left rear,
and put the short shoe in front as per an earlier post on a different thread. My fault, didn't know what self
energizing brakes are. Well, back to the shop, at least I'm getting smarter,,,,,, the hard way ..............
Reply
Report Edit
