Best Engine Swap for 1951 Jeepster
Oct 2, 2011
4,643
Wrentham Ma.
If your doing a restoration you would put the same engine in it as it came with. If your modifying it then easiest would be another Willys engine. After that I would assume a Ford or Chevy inline 6 then a V6 and finally a Ford V8 followed by a Chevy V8 both small blocks.
An in line 6 would be a tight squeeze length wise. Small block V8's would be too much power for that light drive train. The V6 Buick would adapt right on the T96 Jeepster trans and would be a lot less strain on that original running gear. if the Jeepster has overdrive you would have an acceptable upgrade in power with driveability. I would suggest however a F 134 instead of the L134. Mostly a drop in with some minor alterations with more horsepower and a better engine.
Mark W.
Dec 6, 2014
425
Silverton Oregon
Mark
CJ
51 Jeepsters came with inline 6's why they have the pointed grill.
Oct 2, 2011
4,643
Wrentham Ma.
A very short 6 cyl. They also put them in earlier wagons with the flat grille so it isn't exactly the grille issue. For a 6 in a 4 x 4 truck or wagon a frame modification is needed.
Cranny
5
Vancouver
Mike
Jeepster
A Jeepster is a special car. Not many left. It is worth much more when left stock than with an after market engine. My first car 50 years ago was a 51 Jeepster with the F head 4 cylinder. It did everything I needed it to do when I was running around as a kid. I admit it is not a great freeway car but It sounds like you are not doing road trips. Just my 2 cents. Please keep it stock!
peewee
Thanks Peewee. Great points. Agree with the historical and nostalgic value of the stock side. Also made need a little juice and freeway time due to living in a metro area. I will seriously consider the stock option.
51’s Rock!!!
pav1
Sep 5, 2017
323
Georgetown Ontario
Jason
Jeepster
Cranny, does your Jeepster have an engine in it now? If so have you driven it in the past with that engine?
