Silicon,
I currently have one on a stand. The bolt holes are spread out in a bit of a vertical pattern. It's a pain. I can get a picture of it and post it for you this weekend, but your best bet is to use the removed bellhousing as a bolt pattern. Lay the bellhousing on the floor (transmission side down). Remove the holding fixture from the engine stand and arrange the legs over the bolts.
My stand is of the heavy duty 2000lb variety and came with "long" legs. Luckily I had two short legs from a previous stand because I had to use them to get the bolt holes lined up. If you are using a standard engine stand you might be ok. I used a standard stand back in 2002 for one of these, but I can't recall if I changed the holding legs. What I do remember is the queezy feeling I had when I watched it droop. These are heavy engines. They will max out the stress level of a standard stand. That's why I wen heavy duty this time.
Anybody remember how to change the picture size so they will post properly??
P.S. I don't know if you are familiar with this engine, but to remove the belhousing you first have to remove the clutch assy and then the fly wheel. Then you can access the three hidden bolts in the bellhousing. Yup, it's completely backwards.
NOTE: After you remove the nuts from the flywheel studs, you still will not be able to pull the flywheel out. You have to use a LONG punch and tap the flyweel bolts back. Then you have enough clearance to pull the fly wheel out. Yeh, it's fun. Obviously, Willys did not have a better idea.
