AND SO IT BEGINS: 1956 CJ5 total basketcase rebuild...
rocket
Sep 3, 2015
3,690
Sierra Mtns
Rodney
Nice job once again Rodney Great compromise. I think they should maybe be removeable incase you get into some heavy rock sliding (Just something to mull over when you can't sleep) ;) I'm still trying to decide what to do about steps. your approach gives me something to think about and keep me awake. Thanks:rolleyes:
Three bolts per side and they come off. If I wasn't getting so old and decrepit,;) I wouldn't worry about a step. Plus my wife is only 5'1" and it was a big step for her. :confused:
rocket
Sep 3, 2015
3,690
Sierra Mtns
Rodney
Another small accomplishment today. Since I used Flush mount LED Tail lights, the wires and terminal block are inside the rear fender well.
20211123_121344.jpg I can just imagine rocks and dirt, mud all thrown up against the lights and wires. Not a good thing. So I looked under the Land Rover Donor car, and yep it had metal guards with a support strut behind the rear tires, with a bottom flange for mounting mud flaps. I cleaned them up and added a short piece of angle to the top of the fender well and drilled a couple holes. Bolted it all together.
20211123_134727.jpg Then back to the bone yard for a semi mud flap I've been hanging onto for years. Another freeway roadkill I picked up. I cut it in half and notched it to fit and bolted it to the Rover splash pans.
It went quicker and easier on the other side.
Even left the chrome panel on the bottom.
The poor old skill saw sure needs a new blade. The thin chrome is backed up by another heavier galvanized piece.
rocket
Sep 3, 2015
3,690
Sierra Mtns
Rodney
I got to looking at the Hurst Mr. Gasket shift boot and retainer plate. I didn't like the looks of the retainer plate. Maybe 16 Gauge steel with 4 screws. I'm still amazed how flimsy some of the parts we get now a days are.
So I laid out the pattern on some more of the 1/4" aluminum scraps and started to whittle one out with 8 retaining bolts instead of four.
I drilled 5/8" holes for the corners and used the 4 1/2" cut off wheels to open the center and cut the piece out of the scrap.
A little sanding and cleaning up and it looks pretty solid compared to what came with the boot. The chrome plate could not be tightened with out distorting and mashing the boot. And it only had four mounting screws.
Then I transferred the holes in the new plate to the tunnel cover and drilled and taped the tunnel cover. I then drilled the tunnel cover mounting holes and transferred that pattern to the center tunnel. I then drilled those holes and installed the 1/4" 20 U-Nuts in the tunnel. And bolted the entire mess together.
When the dana 300 twin stick boot shows up, I'll do the same with it and make a 1/4" aluminum hold down plate for it. "I bought the little Dana 18 boot. It's up for grabs if anyone wants to pay shipping only." Then I'll pull the floor plate back off and add weatherstrip to it, to keep the engine bay fumes out of the cab.
Grateful and Thankful, and you all have a wonderful Thanksgiving.
"Keep Moving Forward"!
rocket
Sep 3, 2015
3,690
Sierra Mtns
Rodney
Christmas Tree adventures in the High Sierras. Sorry, I left the Willys at home.
We went up through Foresthill today to Robinson Flat at about 6,000 ft elevation, then across Grouse Ridge to Mosquito Ridge and back. We had been up a couple weeks ago scouting out Trees and marking the good stands on GPS. We took the Dodge 3500 and my son's Suburban
Today we had three Christmas Tree permits for the Tahoe National Forest and knew just where we wanted to go.
It was a great family outing with my son and his family.
Our Tree.
One for Great Grandma that Makayla helped pick out.
Jonathan's tree.
Picknick on a stump.
Found a nice spot to camp and do a little gold panning lower down the mountain. Next Summer.
My Bride and I had a good day out with family..
Maybe by Monday I might be able to get back after the CJ5 project.
timd32
Jan 4, 2020
1,001
NJ
Tim
What kind of trees did you get.
We typically get Fraiser Fir out here from a Local farm.
But last few years running a artificial one for a little bit, since kids are still pretty young.
Bitzf4
Oct 13, 2020
393
Hastings mn
Jim
We went up through Foresthill today to Robinson Flat at about 6,000ft then across Grouse Ridge to Mosquito Ridge and back. We had been up a couple weeks ago scouting out Trees and marking the good stands on GPS.
Our Tree.
Jonathan's tree.
Pretty country. When I was at Mather tried to spend as much time up your way as we could squeeze in. But had a 1 year old and one on the way so it wasn’t easy. Our son was born at Mather in 79.
Bitz
rocket
Sep 3, 2015
3,690
Sierra Mtns
Rodney
Bitz
Jonathan in the pictures just turned 40 last month. Born in Auburn, Ca. My daughter will be 38 next spring.
Greaser007
Mar 1, 2019
814
Anderson, California
Leonard
Ha ! nice score on the silvertips Rodney. :)
My wife received her tree permit for the Lassen National Forest on Thursday, so we'll be headed to the hills Sunday.
You have a Makayla, and we have a Layla. both keepers !! (she looks like you, and probably knows how to drive a fastener with your makita). Layla turned 4yo on the 23rd. "rightie-tightie and leftie-loosie" is what my wife drilled into her brain.
I wonder what influence we have on them while they observe our mechanical puzzles.
Hey, you are moving forward and still adding weight to your dirt-scrambler for grip. :)
rocket
Sep 3, 2015
3,690
Sierra Mtns
Rodney
Makayla just turned 6 last week. My other Grand Daugther is a teenager, and my Grandson is close.
My Daughter Myriah was supposed to be named Lyla Myriah. But She was born on my Grand Mother Lizzy's 88th birthday. So she became Elizabeth Myriah. She came into the world backwards (breech) and has been a Contrary ever since. This is my oldest GD. Samatha.
Hopefully I'll be Moving Forward Monday.
rocket
Sep 3, 2015
3,690
Sierra Mtns
Rodney
And So It Begins. Santa's Elves have vomited forth tons of Christmas Decorations from the Basement, along with new stuff just delivered. I think I be busy on other things than Willys project for a few days.
