OK, so nobody got real excited about the 'hidden capture nut into the seat frame' adventure. I get that. I guess it was a big deal to me because it concluded a coupla different originally confusing things I was chasing - for a long while - and finally got to the Finish Line with 'em.
So here's some other things I've been chasing today.
Nearly a year ago, I started trying to pull together all the pieces that are unique to the early Column Shift set up. There's a lot of such pieces, and some are really hard to find. Like the cover plate over the transmission. No floor shift lever sticking through means it's a different plate, obviously. And it has a little "bump" on it, to give clearance for the transmission breather. Found a really rough one, from this '46 VEC, slowly going back to nature up in Michigan -
I debated if it was good enough to use, it was
deeply pitted when it arrived.
But over the past several months, I would mess with it once in a while. Sandblast, coupla times, acid etch, sand on it.... a little filler, sand it more... Eventually, I felt like it was maybe worth squirting some paint on, to match Chuffy's floor.
So yeah, it came out pretty decent. I won't install it until I do the sizeable project of converting back to column shift of course, which will be in "Phase Two" - after I get Chuffy back on the road first.
And then today, I was messing with all the little fasteners and small parts that go with the manifold set. It'll soon be time to assemble that back onto the engine. And I had to get all the right pieces found or bought. (I also made up a second set of the heat riser parts for the "spare engine" which
@gasoil sent me from Vermont. Slowly getting all the stuff in hand for that engine build later, too.)
Sprayed all the small parts with that "Very High Temp" (VHT) paint which you then have to cure in the oven. 30 minutes at 250° then cool down. Then, 30 minutes at 400°, cool, and one more time at 600. That procedure makes them real hard and temp resistant, I've had good luck with it holding up pretty good. (Tim tells me I'm "officially insane.")
Finicky stuff, painting fasteners...
Well, The Bride is long-since used to my madness, of course, and humors me. I brought the oven rack out to the Shop to attach the fasteners, to get them baked/cured.
Carried that inside, and got the process started.
She took it from there for me.
Footnote: my timing was bad! She was gonna make fresh, homemade bread today. Like flour, and yeast and stuff - from scratch. But now that's been delayed.... Dang! Cause it's really GOOD!
Got them cured, and all sorted. Takes a while. (
@scramboleer likes these kind of photos! haha)
Extra set of heat riser stuff off on the right there.
Even got Chuffy's heat riser assembled. Those always make me dyslexic - which way does the spring, and coil, and arm go.... But got it done - and a little heat shows that it works right.
Then, I moved under the vehicle and started a mock-up dry assembly of the fuel pump and that oil filter line. Looking straight up from underneath here -
That job's kinda miserable work, getting that stuff together. Wanted to practice once, before I do it "to stay" with the goop on it.
And that's another exciting day here, as the sun sets in Medina, Ohio....
(Actually from a few days ago - had a real vivid, pretty one.)
