c-dale-willys
Hello, I'm new to this site and hope someone can help me.
My issue: My Willys runs great but when I come to a stop the idle drops and the engine dies. It seems like it runs out of gas. When I start it, I'll give it gas, it'll run for a few seconds, then abruptly stop.
My vehicle: I have a '62 Willys wagon with the L6-226 motor. The carb is the Carter YF.
A note about me: I'm good with tools and have done a lot of work on the vehicle over the 20 plus years that I've owned it. However, I'm not a trained mechanic and am not good at diagnosing problems. I'm great at following a manual though! Also, over the years I have replaced broken parts but have not upgraded anything, ie. for the most part it's as it was when I bought it.
What I have done: When the problem started I bought a kit and rebuilt the carb. For the first 2 weeks it ran great then it happened again. I tuned up the idle speed (way too high) so I could get it home without restarting it at every stop sign. Strangely the next time I tried it, I turned the idle speed back down and it ran great again. After another 2 weeks, however, the problem came back. I have not driven it since. I adjusted the idle mixture screw but it did not alleviate the problem.
Other possible pertinent information: I replaced the fuel pump three years ago. I currently do not have a fuel filter, maybe some tank crud got sucked into the clean carb? The vacuum line is attached to the distributor but the distributor mount is broken so the distributor is loose (I'm assuming this is not ideal but it was that way when I bought it and it worked so I've never done anything about it, other than a brief fruitless search for a replacement). Not sure if any of this matters.
I included pictures on the off chance someone may see something.
Thanks for any assistance.
Mark
Mark
