'55 wagon body
PKPons
Oct 17, 2017
110
Olmsted Falls,ohio
Paul
  2. CJ
  2. 1955
A question for the wagon guys: Has anyone laid a body on its side to work on the bottom?
Pkpons
cj847
Feb 14, 2017
268
Arkansas
Gary
I haven't, but I wouldn't just lay it on it's side. The body is slightly barrel shaped. I would guess you could lay it on a couple of 4x8 or 4x10 beams and it may work.
Fred46
11
Alliance, OH
Fred
  2. Jeepster
  3. CJ
  2. 1950
  3. 1955
You could check around for a used body “rotisserie” to buy or borrow or rent. That would better support it and prevent any unwanted flexing or collapse. Then you could rotate as needed and roll around.
RandyP
Aug 30, 2016
480
Central Texas
Randy
A question for the wagon guys. Has anyone laid a body on its side to work on the bottom.
Pkpons
Look at Agar Agar's post- (50 Wagon S 10 chassis) under the Build section. I think he did lay his wagon body over on its side to access the bottom.
Randy
PKPons
Oct 17, 2017
110
Olmsted Falls,ohio
Paul
  2. CJ
  2. 1955
Thanks to all that replied. Looking at Agar's post, it appears to be possible to lay it on its side
Pkpons
Fireman
Jan 19, 2019
32
Newberg, OR
Robert
I laid one on its side in heavy grass and soft dirt to do extensive repairs. If it was a hard surface then I agree with Phil that you could damage the sides easily. If you don't have a lot of body repair experience the rotisserie/build a wood frame is good advice.
A very big caution though, is that if all the supports, floors and side rails are removed or repaired while in this position you could lose the shape of the structure easily. I would recommend this technique only if you tack weld angle iron cross bracing extensively and know what you are doing from bodywork experience. If it was a simple floor pan replace then no problem but my 2 cents is that its like peeling an onion under there...you keep finding layers to fix and shed many tears. It almost always is worse than it looks from the start.
RandyP
Aug 30, 2016
480
Central Texas
Randy
If you lay it over on one side you will have to flip it back again to work on the other side, several times. While on its side it won't be easy to work on either the side that's up or the side that is down.
I built a rotisserie for my wagon and used it for both the frame repair and the body. It made working on it much easier due to having it at a good working height.
Randy
PKPons
Oct 17, 2017
110
Olmsted Falls,ohio
Paul
  2. CJ
  2. 1955
Randy
Randy,
Would love to see a pic of the rotisserie you built
Pkpons
RandyP
Aug 30, 2016
480
Central Texas
Randy
I have tried to post some pictures a couple of times but the system wouldn't let me for some reason??
If you go to my build thread (Randy's 1950 Wagon Project) starting at post #30, there are some pictures of the rotisserie.
Randy
