85 full size Bronco, 351m, C6What frame is under it. I see coils up front.
LOL. I'd call it The Beast. The vertical grill bars and missing headlights give it a skull face -- it could be out of a Mad Max movie.I'm figuring out the pic size lol, and yes my kids call it...The short Bus
Lol, I'm presently looking for the horizontal grill bars and headlight bucketsLOL. I'd call it The Beast. The vertical grill bars and missing headlights give it a skull face -- it could be out of a Mad Max movie.
Thanks, I caught that on your next post.85 full size Bronco, 351m, C6
I did the swap. I would say pretty simple. Bronco has the same wheel base it fits nice. I did need to hollow out most of the grill to fit the radiator and an electric puller fan. Made up new body mounts and bolted to the stock Willys location. I basically used everything from the bronco, wire harness, pedal assembly, gas pedal, booster/ master cyl.,steering, gauges( fit the bronco gauges in the willys cluster) even used the gas tank- rotated it 180 for passenger side fillI like it! Did you do the body swap? Was it "simple"ish?
Also this is setting stock bronco height with no lift at all with 35" tires, the rear mount of the Willys is 3/4" off the Bronco frame. That's the thickness of my poly mountsI did the swap. I would say pretty simple. Bronco has the same wheel base it fits nice. I did need to hollow out most of the grill to fit the radiator and an electric puller fan. Made up new body mounts and bolted to the stock Willys location. I basically used everything from the bronco, wire harness, pedal assembly, gas pedal, booster/ master cyl.,steering, gauges( fit the bronco gauges in the willys cluster) even used the gas tank- rotated it 180 for passenger side fill
This is where I took off the radio delete panel, and cut out the lower part and welded a tab on each side to bolt the column up. Like I said I used all the parts from the bronco
