agne2520
Hey all. Brian here. Thought I would finally make an attempt at a build thread. 51 pickup I've had since 1981. Retired now, so I have some time and a little more disposable income. To date I have totally boxed the frame and had it sand blasted and painted. Using narrowed axels from a 73 blazer and had the knuckle drilled and tapped for hi steer. Front springs are also from the blazer and rear are stock. Saginaw steering box, s-10 fuel tank with in tank fuel pump, 70s vintage GM tilt steering column, fire wall mounted pedals, and power brake set up. Just finished rebuilding a 92Pontiac firebird 305TPI engine, which was my first attempt, so we'll see how that goes. Primed it and got oil to the rockers, so, so far so good. Will hook up a pressure gauge and see how much oil pressure I have. Rebuilt the np 241 transfer case and installed the drive train in the frame and everything looks good. Have to take the 700r4 tranny back out and have it looked at. Guy I bought it from said it was in good shape, but, of course I have my doubts. Finished the metal work on the cab, which included firewall, both floors, tunnel, rocker supports, and rockers. Usual stuff. I decided to use two body mounts under the nose, instead of the stock center mount. Thought it would help make the body sturdier? Started body work, but my shop isn't heated, so will wait till spring. Bed was beyond repair, so I decided to build one with an M 416 military trailer in mind. Had the sheet metal bent up at a local shop and started to weld it up, but haven't finished. Built gauge pods and console, and sprayed with Raptor liner. Gauges are Marshall and seem to be nice. All for now.
