50wt motor oil vs 90wt gear oil in trans/t-case
5,734
#1
When I rebuilt my transmission and transfer case a few years ago, I filled them with 50wt racing engine oil, based on the recommendation by Novak. The transmission seems to shift better, and I like the oil because it doesn’t smell like the 90wt gear oil.
Now that I’ve added an overdrive, I’m not sure about the 50wt. Advance Adapters recommends 90wt for the overdrive.
Thoughts?
Oct 2, 2011
3,520
Wrentham Ma.
#3
I would not even think about playing games with gear oil in an old Jeep with overdrive. 90wt it is for me.
Blindmelon
Aug 10, 2014
1,336
Agua Dulce, CA
Larry
#5
I went ahead and filled everything with 90wt. I hate the smell...
Yep, I also hated the smell...And my climate is warmer so I used 85W140 .... And no matter what I did there was always a drip or two
stinking up the truck... My T5 uses ATF and zero leaks... My Dana 300 uses 90W but no leaks.. And my floor has only two sticks
compared to the 4 it used to run... Just sayin' a major factor in upgrading to the T5/D300 was the smell..
cwdtmmrs
Jul 19, 2012
1,013
Tim
#6
Yeah, hard to be a D300. One from a Scout is a direct bolt on too.
5,734
#8
Pete hopefully you aren’t using something harmful to yellow metals, I only use NAPA GL1 Mineral oil https://www.napaonline.com/en/p/FCA65201
An OD is too precious for any level of risk
Does the Napa mineral oil have a strong smell?
Tim at Novak says the 50wt engine oil is fine, as long as it has the SL rating. Might change it out the 90wt at some point.
cwdtmmrs
Jul 19, 2012
1,013
Tim
#9
Tim at Novak says the 50wt is fine, as long as it has the SL rating. Might change it out the 90wt at some point.
There is a retired oil engineer/specialist on the Rolls Royce Forum. Do you want me to check with him?
airportops
Jan 1, 2019
30
Conroe, Texas
Terry
#11
This subject has received a vast amount of discussion over on the CJ2A forum. The consensus seems to line up with wunderwillys thinking and the use of the GL1 mineral oil. They have chemical analysis from different engineers and chemist going over all the possibilities for harming yellow metal - and the always popular personal opinions ;). I kind of thought the issue had been settled until I got my Wagon and started looking around for info on it. I have been using GL1 in my 2A, with the overdrive, for decades with no problems - Have Fun.
Jul 19, 2012
1,013
Tim
#13
Wouldn't hurt, good to know for sure.
Here is the response I received from the oil guy I trust on the RR forums:
The fear of a GL5 oil damaging a gearbox is fiction fueled by internet gossip. That 'problem' was solved over 50 years ago before I was in Army petroleum school in 1972. Unless there is a shifting problem there is no reason to use anything other than the standard GL5, 90W gear oil as your manual recommends. If it has hypoid gears then GL5 is required to avoid gear damage. GL1, or motor oil, provides no such protection. 50W motor oil is heavier than 90W gear oil, harder to find and, like the GL1, has no EP additives for heavy gear loading so I don't see any advantage.
Here is a 2nd resp[onse:
I posted my results years ago. Nothing is different today. Yellow metal damage today is mostly a myth.
https://rroc.hoop.la/topic/ep-...-potential-corrosion
Interesting info if you want to wade through it.
5,734
#15
Thanks for asking and posting his response here. Unfortunately the article on the RR forum is member's only access. For now, I'm going to keep the 90wt in there, and run it for a while.
Jul 19, 2012
1,013
Tim
#16
Here are the highlights:
I am about to install all new parts, including brass syncrho rings, into a Borg-Warner 4-speed. The potential corrosion of such brass parts by gear oils has been mentioned on our forum a few times over the years. It is widely discussed on the WWW where its severity is generally, IMHO, very overstated for modern gear oils. The test for corrosion of such yellow metals (those that contain copper) are not done using brass but with bare copper which is more easily damaged. At least in the USA, the test normally used is ASTM’s D-130, Copper Strip Tarnish Test. The results of this test are normally reported on the Technical Data Sheet of any oil you might want to use, that is provided you can find the TDS.
Since I was trained years ago by the US Army as a petroleum lab tech I conveniently have a set of the ASTM standards which include this test. I couldn’t find a data sheet for the oil on my shelf although on the jug it says ‘Protects against the corrosion…of copper…’. Other than 80W-90, no other ratings are on the bottle except GL-5. As a demonstration to myself I decided to run a psudo-D-130 test on the Super Tech GL-5 80W-90, EP gear oil just to see what happened. Some of you might be interested in the results. I can’t duplicate the required temperature stability of 1 degree Celsius or a few of the other details so its not a true D-130. I also don’t know that the Alfa Romeo copper oil plug washer I used is 99.9% pure copper as specified. But the test is about as close as most of us could achieve in our own kitchens and I doubt that its far from what an official D-130 test would show.
This test calls for a mechanically cleaned, bare copper strip to be immersed in the test fluid at 212 F for 3 hours and the change in color of the copper strip is compared to an official chart. The darker the strip, the more corrosive the fluid, i.e. oil in this case. The chart is a visual aid to better define the numeric classifications which range from 1 (slight tarnish) to 4 (corrosion). Not having a chart, I have to rely upon the descriptive words for the various categories which range from 1a (Light orange, almost the same as fresh polished strip) to 4c (Glossy or jet black). Just for kicks I also threw a new syncrho ring in with the copper washer.
I heated the oil in a 2-qt sauce pan and monitored surface temperature with a calibrated IR gun (with emissivity adjusted to 0.95) as well as mechanical, liquid and electronic immersion cooking thermometers some of which proved quite inaccurate. Even the lowest simmer setting of the gas flame was too much for 212F so I had to cycle the burner on 5 min, off 2 min, such that the oil temp cycled between 205-220F after an initial spike to near 235 F. If anything, I would say that I exceeded the specified temperature and should have more corrosion than an ‘official’ test would produce.
The attached test results picture taken in afternoon sunlight shows the synchro ring and copper washer with the washer’s left side re-polished after the test. The left side of the copper and the 2nd synchro ring are included as a indicators of ‘before’ colors. I don’t have to tell you which is the tested brass ring since, as expected, the rings look identical (its on the left). The copper is definitely not Claret red (2a) not even Dark orange (1b) but I would classify it as 1a (Light orange) which is the lowest rating available. Typical gear oil tests allow at least a 2a if not a 3 rating. (I have never seen a modern, tested gear oil data sheet that reported a 3 rating even if it might have once been allowed. The latest MIL-PRF-2105E from 1995 only allowed 2a.)
Am I saying that all EP gear oils are perfectly safe for all applications? Not at all. But this test reaffirms my belief that potential hazards of GL-5 rated EP oils are often greatly exaggerated. Even this cheapest of gear oils tests perfectly fine in terms of copper corrosion. If you are concerned about some oil you might want to use either check the data sheet or perform your own D-130 test as I did.
Yes, this thread is about GEAR oil specifications, particularly the GL-5 specification. 50 years ago before the GL ratings were being used such an oil would have been called EP (Extreme Pressure) which explains the title of the thread. Such oil is not necessarily limited to manual transmissions but would/could also include oil for differentials, steering gears, etc. Motor oils use entirely different wear additives and ratings.
You will find that nearly ALL petroleum products have a copper corrosion test as part of their specifications. Even petrol has to pass that kind of a test. Of the various POL products (Army-speak for Petroleum, Oil and Lubricants) GL-5 gear oil, among others, has had a variety of claims for the past 50 years that the 'new specification is dangerous for your car'. Some go so far as to claim that GL-5 does not even require a copper corrosion test (proving its hazard) when in fact it has a more stringent copper corrosion test spec than other gear oils. The general rule is that it takes 70 years for such rumors to cease so we have maybe another 20 years to go.
To illustrate the gravity of the problem we had a club member just recently who was nearly convinced to put an entirely unsuitable oil in his hypoid differential for fear of this non-existent 'hazard' from GL-5. Had he done so, actual damage would not have been prevented but, instead, virtually guaranteed.
