This is just sitting there waiting for me to finalize my decision on where to park it permanently and fabricate some mounts.
I really like the mounts that were in the Burb. Going to replace with new and work with them in my motor mount fabrications.
These garden variety truck 5.3 engines were built to be swapped. This bad boy has a nice flat section of cast aluminum oil pan about 10 inches long on the front portion of the bottom. I parked it on top of a chunk of 2x2 .250 wall tubing clamped to the bottom of the frame rail and it self levelled side to side. With a little lift with the cherry picker, a little shove and it moves front to back or side to side, really sweet for simple mock up.
I am playing with wood spacers between the square tubing and the frame until I get her just the right height for steering shaft clearance, front driveshaft clearance etc. Right now I have a section of 2x3 spacing tube down and a couple sections of 3/8" plywood between the square tube and oil pan.
Duane![]()
Sent from my SM-G920V using Tapatalk
I pushed the firewall 3.25 inches with the original intention of keeping the mechanical fan with room for AC condenser up front of the radiator. Now after a little education, the plan is electric puller. I also wanted 2 inches minimum clear between the engine and firewall to keep from having too much heat in the cab while idling through 100 plus degree deserts. I am also going to put aluminum heat shields on the firewall and floor. I plan to wrap my exhaust system as well. Retaining dual Catalytic converters so I don't fume out my fellow Jeepers.Duane... sweet work buddy. Question on the firewall as we are doing some floorpan repairs here waiting for the cherry picker.
Looks like you pushed the factory press back a few more inches. Needed to with the wagoneer frame? Or are you setting it back to use the factory mechanical Fan/clutch?
We are going to wait until the Jeep swap meet coming in March to locate a transfer case (pass drop- maybe a NP241c) then we can mock up the whole assembly to set to not needing to modify drivelines. I’m going to guess tho that’s still going to be needed. As much as I’d like to go manual, the 4L60e would be good for the wife.
Good to see progress! KTF!
I regret starting with such a crummy body. It would be done by now without all the bodywork. 4 adult children, house stuff etc leaves little on the table for the Willys budget and shop time, so I make do. The plus side is I have zero regret modifying as I replace and repair panels as this wagon was headed to the crusher.Excellent progress, Duane. I need to go all the way back to the beginning of your thread and read about your journey so far. It's raining today, so that might be a good time to do it! Meanwhile, I'm loving the body you have to work with - mine is far worse, rust-wise. I'm not the best body-man, so some of the creases and dents will remain, even when I finally get the rusty panels replaced and the truck painted. I figure they were hard-won 'badges of honor', so why do away with them! (At least that's the way I rationalize things, since I don't know a thing about my wagon's history!) Meanwhile, most of the body has been in primer for quite a while, under a suspended tarp while I work on the frame. Great build!
