..Hey Lorne..
.Allright here,...have a look at Davids site......
http://www.jeep-trucks.com/index.php...on=disassembly..... It is a virtually step by step tutorial done by a fellow Forum member....on how to disassemble and reassemble your doors .... some of the pics and explanations are missing but most of the information is there to the point to allow you to figure things out...
This along with a few other sections of the truck ...you could also locate a Willys service manual and it will give you the general guidelines on how to install your windshield.
I installed the windshield in my 51 truck by myself although it took me 3 months and 30 attempts to do so .....the doors were pretty simple and straightforward ... only piece of glass that I have not installed in my truck is the rear window since it was already in place when I bought the truck so no need to replace yet.
To remove the windshield glass you simply take a small flat blade screwdriver on the outside of the windshield upper edge of the rubber and put the screwdriver under the rubber flange and pull it down and basically push the rubber into the cab a little at a time working your way across the top and down the sides a bit you will get to a point where you will have the glass and gasket loose and you simply push it in as the windshield goes into the cab for removal. it is the same for glass installation the windshield goes in from the inside only. It would be very helpful if you had a helper to help you remove the glass so that it does not fall in when you push the rubber gasket in. Same for installation I did mine by myself though it would have been better if I had an extra hand
So give that link a good read through and if you have any extra additional questions on anything don't hesitate to ask.
Hope this is of help to ya..!!!!
Larry
