Tree Top Flyer
Just another dumb question from a rookie flat fender builder. I bought my "46" in boxes, and most of this build has been like a blind man in a mine field. I am getting ready to drop the tub onto the frame, and my question is: The front attach points, tub to frame, are different from the rest on the frame brackets. The bracket is bigger, and appears to need a longer bolt to go through both the upper and lower holes on the bracket. If that is correct, then do I need to add a "sleeve between the two bolt holes? If not, why is this bracket so different?
Also, at the very back of the frame, should there be brackets of some kind to secure the tub to it as well? This build, with so many things missing is trying my patience! I would appreciate any help you all could give. Does anyone know of a exploded view of the frame? Thanks.
