Back again
It looks like I have fixed my problem
Made up an adapter to fit the Stromberg carbie today and fitted it late this afternoon
Took it for a test drive of about 20 miles and it ran the best it has ever run
Better acceleration
More power, it even accelerates up hills
I will take it for a much longer run tomorrow, but the way it went today I am fairly confident it is right
I have a few things to tidy up and remove all my diagnostic equipment etc first
All other components are now back to how they were a week ago
It has a small stumble just off idle but I have not adjusted the carb at all since it came off the ford engine
The Carter was Professionally rebuild less then 1000 miles ago
So I did find the timing pointer was out by 10 degrees, The vacuum advance had a small leak, BUT the carb was the main issue
Now I have a finely tuned Willys with a stromberg Carb
This is the adapter
Thanks for all the suggestions,
I hope this thread helps someone else out if they have a similar problem
It certainly makes it a lot easier to diagnose when you have all the parts at hand, I think I have more than recovered the cost of my spare wagon in this exercise
Anybody want to buy a
used Carter Carb
