Likes Likes:  196
Page 1 of 45 12311 ... LastLast
Results 1 to 10 of 446
Thread: Pete's 1960 Wagon
    Administrator Pete's Avatar
    1960
    Wagon
    Sep 2009
    Hailey Idaho
    5,285
    Pete's 1960 Wagon
    Click here to read all about the arrival of my wagon and a bunch of pictures of what the wagon looked like when it arrived on my doorstep...
    I did some searching around a bit for another axle over the last couple of weeks and the best I came up with is a complete running drivetrain and frame from a '62 wagon for $750 that is a couple of hours away. The seller wants to sell it to someone with a 2wd that is looking for 4wd running gear, and doesn't want to part it out. I didn't really want the engine, and it likely has most of the same issues as the stuff I already have, so I decided to just work with what I've got for now.
    I'm not sure yet if I want to keep my wagon stock or not, I have only driven it around the block once. Until I get a feel for what I've got, I don't really want to dump a bunch of cash to rebuild the stock stuff yet. With that in mind, and the fact that I don't have any cash anyway, I got after my rear axle this weekend and got it cleaned up and ready to use.
    Here's what I started with, bad welds on scavenged axle spring perches. This wagon was apparently converted to SOA at some point, and then changed back again. Both front and rear axles have spring perches welded on the top side of the axle.
    The spring perches that were put back on the bottom of the axle to change it back to SUA were cut off something else and booger welded to this axle, and were put on almost 2" off center :roll:
    I cut all four of the perches off of the axle and cleaned up the tubes so I could weld new perches on in the right place.
    I also welded up the hole that was burned through the tube by the hill-billy welder that put the old perches on.
    I bought new perches from Ryan, The Jeep Guy, check out his stuff from the link on the portal page.
    Got the axle in place under the wagon, adjusted the pinion angle, and tacked the perches in place. Pulled it out again, welded the perches on, and sprayed some paint on them. I'm going to paint the whole thing, ran out of paint that I had on hand.
    The next issue is the rear brakes, they are missing all of the e-brake hardware, the shoes are just about gone, and the wheel cylinders are, I think, from the front. The cylinders don't have flare fitting holes in them, and they had rubber lines that ran to a hard line to the "T" fitting that went to another rubber line to the frame. The cylinders don't have the right bolts holding them to the backing plates, stacks of washers because they are too long, etc. And, outer axle seals are bad too.
    I think I'm going to just shit-can these brakes and buy the 11" brake kit from The Jeep Guy.
    These are Bendix self adjusting brakes and come complete with new drums and backing plates, and all the shoes/ebrake hardware. It's a bolt on deal, so if I decide to swap the axle for another in better shape at some point, I can keep the brakes and move them over to another Dana44.
    That's it for now... more to come.
    Founder of OldWillysForum.com
    My 1960 Willys Wagon Build Thread | Instagram
  2. Likes Blindmelon, boomerinmn liked this post
  3. #2
    Well-Oiled cnsay's Avatar
    Chris
    Wagon
    Jun 2010
    North Idaho
    1,482
    Re: Rear differential update
    Bugger welds hardly covers the crap on the old spring mounts. Looking much better now, keep us posted.
  4. #3
    Precision-Fit 73fj's Avatar
    Chris
    Wagon
    Oct 2009
    Grande Prairie, Alberta, Canada
    553
    I think swapping out the brakes is an excellent idea.
    I ain't gonna hit ya.......ahhhh the HELL I ain't. John Wayne.
    1959 wagon, full frame off in progress, 1973 FJ 40, 1977 FJ 45.
  5. #4
    1960
    Wagon
    Sep 2009
    Hailey Idaho
    5,285
    Quote Originally Posted by 73fj
    Ordered the 11" Bendix brakes from The Jeep Guy yesterday, should be here in a couple of days.
  6. #5
    Well-Oiled
    Pavel
    1965
    Wagon
    Sep 2009
    Vancouver, BC
    1,413
    Pete:
    The Bendix rear brakes you ordered come with new drums, you say, but am I correct in assuming (always very dangerous) that you will have to attach the new drums to your old hubs? That can be a bit tricky - I have experience with removing drums from front Dana 25 hubs....
    Does the new brake set include new lug studs? When I used Dorman lug studs on the front brakes, I discovered something interesting - the spline count on the new studs was one (1) different from the originals. I carefully ground off the old stud heads inside the drums and then tapped them out (toward the outside). That way there was no damage/stretching of the hub material where the old studs had been swagged into place at the factory. I asked advice at a local 'brake shop' and the boss said the different spline count was not important (he used crustier language being impatient with me for asking such a stupid question).
    Anyway, hope the new rear brakes work well.
    About your comment as to whether or not to "keep your wagon stock...", permit me to recommend that you get it fully driveable for a while and then make that decision. In our case, I drove our '65 wagon to work daily for 3 months after which it was obvious to me that I wanted more modern steering and brakes, plus 3 point seat belts etc. Our daughter simply didn't have the arm strength to park stock steering 'Bluebell' on pavement - Saginaw power steering conversion solved that. I was never able to get the drum brakes to work properly, nor was that local brake shop able to bring them up to a minimum standard - Chevy front discs have made a big difference but I am still not at all satisfied with brake performance. I suspect that power brakes will be needed.
    While I really like the Tornado OHC engine, the T90 3spd is at a disadvantage in city driving - I want to update to a T19 (Ford) all synchro 4spd one day. I really do not understand why these vehicles didn't all come with T98 4 spds since they were available on special order... how much extra would the sticker price have been in those days?
    Cheers
    1965 Willys 4X4 wagon (Tornado OHC 230 I6 with Ford EDIS ignition, T19 4 speed(soon), Spicer18 in D20 case, D44 rear, D27 front with Chevy discs, Koenigs front winch, Saginaw ps, 4 shoulder belts) Website: http://pavelsuniverse.com/willys/willys.html
  7. #6
    1960
    Wagon
    Sep 2009
    Hailey Idaho
    5,285
    Quote Originally Posted by pavel6
    Pete:
    I hadn't thought about the hubs... I don't know if they come with new hubs too or not. I just sent an email to Ryan to find out.
    This is my plan for now. I did this with my '50 Plymouth, and loved it stock. The old Lockheed brakes worked very well on the Plymouth, once they were set up correctly with an Amco Brake Gauge. I loved the character the flathead six had, and I had a ball getting the most I could out of it. I drove the car daily and all over the western states without issue. I also have a '53 Chevy pickup that I've had for 30 years. I drove it stock for about 12 years, and then dropped in a 350 with automatic, mustang II front end, etc. It drives like a race car and is a blast, but it really isn't a truck anymore... I want to see what the Wagon is like as is before I change it's character much. I don't expect it to drive like a modern rig, and I like driving old stuff too, so I will likely keep it stock unless it becomes tripping over dollars to save dimes.
  8. Likes Rodger liked this post
  9. #7
    1960
    Wagon
    Sep 2009
    Hailey Idaho
    5,285
    Quote Originally Posted by Pete
    Pete:
    Your right Pavel, I will have to re-use my original hubs. Ryan said the new drums slide on from the outside, and aren't pressed on like the originals. I should have everything by Thursday, so I'll take some pics and post them.
  10. #8
    1960
    Wagon
    Sep 2009
    Hailey Idaho
    5,285
    Weekend update
    Got some more done on my rear axle this weekend...
    I made an impromptu axle puller out of a 2x6 and one of the old drums as a spacer.
    Took a sledge hammer to get the axles out. No surprise that they were nice and filthy.
    The bearings don't look visibly bad, but I'm sure they could be replaced. Doesn't seem like they have ever been out.
    And with the hole burned through the axle tube by the previous owner, no surprise to find the tube full of sand... :roll:
    There is so much wear in the gears and axle splines from the gritty lube that was in there, the whole thing is pretty much shot. Since I won't have the cash to replace it for probably a year or two, I decided to just clean it up as much as possible, and put it back together. I repacked the bearings, installed new seals, and mounted the new 11" Bendix brakes.
    Even the hubs need to be replaced, one of them has been hacked on with a torch, presumably to cut off rusty lug nuts. The other was put on with the key too far back, and it stretched the keyway out of round at the seal surface by about 1/8"... I used a file and got it round again, I think it will be ok until I can find another axle. The brakes are a bolt on deal, and will be swapped on to the new axle whenever that happens...
    I fab'd a new brake line for the axle last night, now to get it back into the wagon, and get the brakes bled.
    More to come-
  11. #9
    Well-Oiled
    Kevin
    1962
    Wagon
    Oct 2009
    Georgia
    1,821
    Re: Pete's '60 Wagon
    Nice work Pete !!!! safe and dependable....but your shop is way to clean :lol:
    Moab 3 - Been There and still eating sand
    My Build Post is coming to an end... Progress 62 OlllO ....I'm happy and sad.
  12. #10
    Aug 2010
    Montana
    100
