Likes Likes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Welding body panels, butt or flange?
    Well-Oiled
    1958
    Wagon
    Jun 2011
    Allen, TX
    1,066
    I took a welding class yesterday in preparation for installing some body panels and the instructor had recommended getting a flanging tool and putting a flange on the original piece of body for the replacement panel to sit on. It seems that most of the members builds that I have seen that involved installing new panels that they butted them up to each other. Any thoughts from experienced body guys?
    Thanks
    Dan
  2. #2
    Sharpest-Tool Ken P's Avatar
    Ken
    1955
    Wagon
    Dec 2012
    Canton, Ga.
    381
    A butt joint is best but sometimes flanging will do. I had taken sheet metal forming & welding at a vocational school many moons ago. I had checked out pricing on a refresher course but it is out of my price range at the moment. There are tons of instructional videos on YouTube. I have the equipment but will need to practice a lot before I do anything on the wagon
  3. #3
    Sharpest-Tool BruceR's Avatar
    Bruce
    1951
    FC
    Sep 2011
    East Texas
    207
    Butt is king, if you have a little hammer welding experience it is even better. The only time I used to flange was when I used a spot welder.
    Bruce
  4. #4
    Sharpest-Tool
    Nov 2009
    Wis
    275
    A flange will hold moisture,which makes rust , which makes more welding.
  5. #5
    Well-Oiled Gojeep's Avatar
    Marcus
    1948
    Pickup
    Jan 2010
    Victoria Australia
    2,814
    Flange joins will also show through on final paint work on hot days due to different expansion rates.
  6. #6
    Precision-Fit mikec4193's Avatar
    Mike
    other
    FC
    Jan 2010
    Mechanicville ny
    853
    Hi Doge
    If you want strength do the over lap method....I use overlap joints (1/4" or less) for my floor patches and I butt weld all the outside patches. The key seems to be small tack welds...I tack weld everything and then fill in between with more tack welds. The more time you have the heat on the panel more chances for warping to occur. My last project was a 1947 CJ2A and it has over 50 patches on it to bring it back to where it used to be.
    Oh yeah I dont finish any bodywork, I butt weld, grind the tops off the welds and then shoot some rattle can paint over it. I like old Willys that look their age...I love the patina of an old finish on metal...
    My smelly old 2 cents....
    MikeC
  7. #7
    Bruce
    1951
    FC
    Sep 2011
    East Texas
    207
    Like Mike says...small tacks then fill in with more small tacks. Be sure to let an area cool before returning to it. I've heard that MIG makes too hard of a weld to hammer...but I can't speak from experience on that.
    Bruce
  8. #8
    Well-Oiled Tom1956's Avatar
    Tom
    1955 1957
    Wagon Pickup
    Dec 2011
    Flushing Michigan
    1,866
    I assume that a butt joint is 2 pieces of the metal that just butts up to one another with no overlap ? And
    A lap joint laps the metal over each other? So that leaves the flange joint.
    So that flange is made with a flange tool that bends the metal to have a Z bend in it, that the replacement piece lies on the Z part and, where the seam is, should be level with each other ?
  9. #9
    Well-Oiled
    1958
    Wagon
    Jun 2011
    Allen, TX
    1,066
    You are correct. I have found both hand and air powered devices that will make this flange. Most have a hole punch on the other side to make a hole to allow the welding of the top plate to the bottom via the hole. I think that I may try both the flange and butt for the parts I need to replace. There will be some sections where the backside is inside of the cab and should not be exposed to moisture and then some that will not be protected on the back side.
    Dan
  10. #10
    Precision-Fit germain's Avatar
    Gary
    1961
    Wagon
    Nov 2009
    Bartonville, TX
    509
