Johnny Mac
Precision Fit
Hi everybody,
R&P 4WD just released their new dual master kit specifically for Willys trucks and wagons. I have been pestering them for some time for one so as soon as it was released I bought one. The kit uses the Wilwood dual master part number 260-7563 and Wilwood residual pressure reducing valves. The valves are for disc brake applications only so if you have discs in the front and drums in the rear you only get one valve. I went with discs all around so my kit came with two.
One of the most important components is the mounting bracket. You can see it in the first picture in the center. The bracket has holes lined up perfectly for mounting to the existing holes in the frame. The large hole on the left end of the bracket as shown slides over the brake pedal shaft and retains the brake/clutch pedals. A cotter pin seals the deal. The opening for the MC in the bracket is actually slotted so there is some movement available left-right for alignment.
The second really important component is the plunger. The plunger is shown in the lower right corner of the kit picture. You can see that one end has an eye opening that slips over the shaft in the brake pedal and the other end connects to the piston of the MC. There is a lockable adjustment connection between the two ends.
Mounting the bracket and MC too all of 10 minutes. I love it when parts fit as advertised. I absolutely hate it when they don't so I was really pleased with the planning of this kit. I put the plunger in and connected it up to the barke shaft to test fit, but decided to remove it until I was ready to start bleeding. Hell, I haven't even run new lines yet.
So I'll let you know if I have any problems when I get there, but I really don't foresee any with the completeness of the kit. Now all I have to do is figure out where I'm going to put the reservoirs!
Cheers!
Johnny Mac
Cheers!
Johnny Mac
