Likes Likes:  0
Results 1 to 4 of 4
Thread: 1957 Willys One-ton Pickup for Sale
    Sep 2012
    3
    Sadly....I have my pickup for sale on Craigslist. Here are the details. Extensive photo gallery with 3 videos is posted to Picasa (link below).
    I have decided to sell my pride-and-joy 1957 Willy's Pickup. If you live in the Overland Park area you may have seen this awesome survivor cruising around town running errands over the past 8 years. It is one of the coolest trucks you'll ever see with a face only a mother could love. The truck runs and drives great. I have put a lot of work into it since acquiring it. . .all to make it more enjoyable to drive. I did not put any money into the body or paint. . .preferring it to look like it was earning its living. It has a Warn Overdrive which really helps make it more drivable around town. It has also been converted to have dual master cylinders and front disc brakes. The truck is completely rewired and has been converted to 12V. The truck spent most of its life in Utah so it is nearly rust-free. It has been garaged since it came to Kansas and has not seen rain or snow since it arrived. The truck is priced at $7000 cash and that price is firm. Serious inquiries only.
    Call 913-897-0402
    Photo album and videos can be seen here: https://plus.google.com/photos/11448...28953912964561
    Description:
    Original smooth running 226ci Super Hurricane flathead straight six. Burns zero oil.
    Warn Overdrive (works in all gears, including reverse)
    Dana T-90 Three-speed transmission
    Dana T-18 4WD transfer case with Hi/Lo
    Dana 25 Front Axle with Warn manual locking hubs
    Dana 44 Rear Axle
    Dual fuel tanks with in-cab tank swap valve(second tank is currently bypassed as it had a leak)
    No cracks in glass
    Minimal rust (practically none) on original body. . .truck spent its life in Utah
    Clean rust-free frame
    Heavy duty rear bumper with ball mount and working vise
    Chrome front bumper with original brush guard
    Original rust-free corrugated steel bed
    Reupholstered bench seat in tan marine-grade vinyl and new foam padding
    Added driver and passenger seat belts
    All exterior chrome trim is present
    All interior hardware is present
    Gun rack
    Electrical updates:
    Painless Wiring 12-circuit wiring harness and fuse panel
    Painless Wiring Battery/Starter wires
    New Starter Solenoid
    Remanufactured 65-Amp alternator with built-in voltage regulator
    Crane Cams Fireball Electronic Ignition
    Newer Battery
    Electric Fuel Pump with engine cutoff safety
    New spark plugs
    New coil
    Two rear 55W work lights on switch
    Rewired original turn signal
    New gauge cluster and speedometer (shows 1200 miles)
    Small tachometer (not currently mounted)
    Unity-brand spotlight
    New starter switch
    New light switch
    New 12v Heater Fan motor
    New temperature sensor
    New fuel sending unit
    New tail lights
    New beehive rear turn signals
    Brake updates:
    Front Disc brake conversion with new jeep rotors
    Herm Tilford Dual Master Cylinder mounting kit
    New non-power Dual Cylinder Brake Cylinder
    Remote Brake Fluid Container
    New Brake lines to all four wheels
    Summit racing 10lb residual valve for rear brakes
    Summit racing adjustable brake balancer for rear brakes
    New emergency brake cable
    New Front Brake pads
    New Rear Brake shoes
    New rear brake cylinders
    Speed bleeders at all four wheels
    New Brake pressure switch
    Mechanical updates:
    New Front Wheel hubs
    New front wheel bearings/nuts/washers
    Cleaned and re-greased original Warn hubs
    Rebuilt Rochester 2-barrel carburetor with manual choke
    Trans-dapt 2-to-1 barrel carburetor adaptor/riser
    New rubber fuel lines and Fram fuel filter
    New MTS polyethylene fuel tank, straps, and mounting bolts
    Restored heater box and ductwork
    Flowmaster single-in, dual-out muffler
    New front and rear shocks
    Tires and Wheels:
    4 New 215/85--16 BF Goodrich Commercial T/A Radials
    5 New Black Cragar steel wheels (Spare does not have a tire on it)
    Known items:
    Fuel sender does not usually talk to the gas gauge all of the time. It usually shows below empty, even when the tank is full. I don't understand why because everything from front to back is new. Probably a bad ground.
    Windshield wipers and linkage are complete but the vacuum wiper motor is not strong enough to move the blades back and forth. It either needs a new vacuum wiper motor or an electric wiper conversion (which was my plan).
    Floor boards were replaced before I got the truck and will need to be replaced in the future. No danger of going through the floor but there are some small holes that have been there since I acquired the car and have not grown.
    Attached Images Attached Images
  2. #2
    Well-Oiled Pivnic's Avatar
    John
    1957 1963
    Wagon Pickup
    Nov 2009
    Conifer, Colorado
    3,750
    Welcome to the Forum ChuckMick. Very NICE Pickup, Sad indeed that you are selling it. I too have a 57 Willys Pickup (Hot Rodded)... Good presentation on your For Sale Ad. (When is it NOT WINDY in Kansas)? I went to college in Emporia and IF it Wasn't windy, you thought that something was wrong! Good luck with letting your pickup go. Pivnic
  3. #3
    Sep 2012
    3
    Thanks. Yeah....sad to see it go but it is not the vehicle I want my 16-year-old to be driving on a daily basis. It turns heads wherever it goes and it seems I can't go anywhere without having to field questions about what it is, how old it is, where I got it, etc... I will really miss that part! Someone with some very basic paint and body skills could easily have a $15,000 vehicle. I don't have those skills or time.
    Chuck
  4. #4
    Jim
    1948
    Pickup
    Aug 2013
    Ninilchik Alaska
    1
