Jeff: VA Gen II supercooler, works well about 98 deg or less, above that cools well, bot heat load on radiator will push engine temp to 230(5.7L 1999 chevy, computer controls) if you don't have a large radiator. I put a 29 inch in just as the 100+ temps ended, so I will not get a temp test till next summer. Option two if you are still in the planning stage is an under body remote condenser with elec fan, no heat load added to radiator.
Dan, I guess schools out now so I could come by one day this week at my lunch break, can be a long lunch no problem. Best if it's not raining, unless you have a covered spot to use. I'll take your number with me, and check the wind/rain forcast for the week, and call you.
Gary
