Mudpuppy
I have a 51 wagon with the original L161...I’ve rebuilt or replaced most of the engine components including rebuilt Carter carb, ignition wires, spark coil, rebuilt the generator (it’s still 6v). Lately I’ve noticed that the headlights don’t get brighter when I accelerate the engine and today the battery barely turned her over but she did start. I took her for an hour drive averaging 45 mph (since I’ve been told the battery doesn’t charge when the engine is only idling). We stopped to have dinner and when I went to start her she was stone cold dead. I got a jump (12v I know it’s not advised) but she started up IMMEDIATELY. As we were driving home as I got up to around 35mph (with the headlights in since is was night by now) she started to sputter and hesitate. I immediately turned off the headlights but the problem persisted once I got into 3rd gear ( I have electronic OD original as well). We made it home but now I’m trying to understand what the problem might be. As I pulled into the garage with the engine still running at idle (and she was idling fine) the headlights were barely illuminating. Any thoughts ? I’m thing maybe the voltage regulator ? I took the cover off (original as well ) and there was some rust on the bottom area I guess maybe from water getting in. I sprayed it with WD40 ( was advised to do so) but I didn’t clean the contacts with fine sandpaper. While she was running a Out a volt meter to the battery leads ...reved the engine and the voltage did not increase which also makes me suspect the regulator ...thoughts ??? Help !!
