nobling
After two days of knuckle busting I finally got the Ross steering box out. Unfortunately I had to cut the sector shaft to do so. I need to get the pitman arm that has the splined and threaded portion seized into it to a shop so a hydraulic press can push it out. Question: How do you experts suggest removing the pitman arm? Can I disconnect it at the hub (four bolts but I dont know what will happen inside the hub) or do I grind down the end of the shaft where the kit goes in to apply pressure to the ball on the pitman arm? I cant seem to post pics.
