skratch
When I bought my 58 CJ5 the PO had installed an electric fuel pump, works OK after I got the pressure regulated. Question is the original
mechanical pump is still on the engine, just closed off with short flex lines and clamps.
The PO said the elec. pump was for high altitude use ,,, ?
Should I remove the mech. pump and put a plate on the block ? I thought of using the mech. pump and having the elec. for backup, I don't know
if the mech. pump is even good. I need to test it before I do the re-hookup.
Any suggestions on how to do that ?
Thanks, John H.
Thanks, John H.
