Gopher8
Knuckle Buster
Hello All, I wonder if anyone might be able to help with a tranny issue I've been having.
Last summer I started having a hard time shifting into third gear. It is only hard after the T-90 warms up. It doesn't grind. It just doesn't want to go. I rebuilt the tranny three years ago and it ran fine after. Now, not so much. I can hear the throughout bearing vibrating a bit so I know it needs replacing. It shifts fine if I double clutch. I tried adjusting the clutch release cable to no avail. The shift forks don't look worn. I'm not sure what to check next.
I pulled the tranny and t-case and I'm ready to get after it. The rig is a '49 cj3a. the drive train is mostly stock. It does have a Warn overdrive.
Any thoughts?
Any thoughts?
