matty49
When I got my truck home last June, I noticed the Speedo needle broke off and lying in the bottom of the gauge window. I also noticed that the stub of a needle was pointing at 45 mph. (The cable is broke about 5 inches from the trans. case.) I pulled my gauge cluster yesterday to clean it up and repair the broken needle, it's a 49 W the rectangular cluster. As I played with the Speedo I couldn't figure out how to set the needle to go from 0 to 80. Mine sits at 45 and when you spin it back to 0 mph it continues on around to 60 mph. I see there is a little stop tab on the wheel for the needle that only let's it go so far either way but it's not stopping it where it needs to be. If someone knows how to reset this thing I would really appreciate hearing from you. Thanks, matty49
Sent from my SM-T550 using Tapatalk
