The top half of the sheet metal box removes, exposing the heater core & retaining straps. Remove the hoses, 3 sheet metal screws on either side of the heater box, midget hands & a right angle screwdriver needed. Remove screws (3?) and 2 nuts around the top at the firewall. Let the box tilt slightly to clear the top studs, then brace the heater box from below since 2 screws are still in the bottom half, screwed from the inside of the car, under the grill & floor mat. Work the top half off the bottom half, probably tight, and your core &core straps will be readily accessible. Heater core is cell type, so a re-core will likely be your only option. Be careful with the box to firewall rubber gasket.
