Eric
next time you put this jeepster on a lift can you measure the driveshaft for me...
Tully
You didn't ask me, but i measured a 2wd Willys wagon driveshaft T96 w/od, I am pretty sure it is the same as a Jeepster (Hollander says it is). It measures 34 3/4" weld to weld, with a slight narrowing of the pipe on both ends up to the welds. The ends are both the sliding Detroit joint I think it's called, (with a flat and round end flange on both ends). 4 and 6 are listed as the same.
