WorkinProgress
Precision Fit
I just picked up an unknown condition motor and then I bought a starter from a member here and now I'm trying to put the two together and get the motor to start I am not getting any spark at the points I have power to the coil on both sides 12v known good coil off another one of my Jeep
I can trace power from positive on coil to negative on coil 2 distributor stud and then to half of the points when open
With points open I put one lead of a multimeter on each side of the points and I have grounded one side and power at the other everything seems like it's how I think it should be but after playing with it for a bit The Wire that's original inside the distributor that goes from the distributor stud to the points begins to smoke and get really hot really fast not while cranking just with power on I'm assuming that means that wire is grounding out am I correct in thinking that or what should I check next
