Likes Likes:  16
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 1952 Willys Aero Wing
  1. #11
    Rick
    1953
    Pickup
    May 2016
    Michigan
    60
    Well, we got Little Wing running this week! Ran so-so but it ran. I actually drove it backward and forward about 30' (no brakes of coarse..) Changed out the ignition switch eliminating the Detroit hot wire that my buddy done to it.. Rebuilt the carb and it ran better. Adjusted the rocker arms so now it is not near as loud. Replaced the upper and lower radiator hoses so now we don't have antifreeze going everywhere. The oil is very clean so I dumped a can of Rislolne in it to help clean things up a little more. I want to get it nice and warmed up then change the oil to straight 30 weight with a zink additive. I am not sure if you gan get the correct radiator hoses for it or not but we made what I had on the shelf work pretty well. The bottom hose is a cut down version of a lower radiator hose for any 66-80's V8 AMC car (NAPA#7399). And the upper is a cut down version from a '50 Lincoln V8. (ROADMAX C0065)
    Now I need to order a fuel pump for it. I ordered all of the brake stuff for it. Hopefully, it will all work!
  2. Likes Pete liked this post
  3. #12
    Rick
    1953
    Pickup
    May 2016
    Michigan
    60
    I made a hub puller for the rear. I welded a hex nut on the inside that just happen to have the same thread as my cheapo vibration damper puller. It worked great!
  4. Likes Pete liked this post
  5. #13
    1960
    Sep 2009
    Vista, CA 92083
    111
    Good job on the puller!
    Mike in Vista, CA
  6. #14
    Sharpest-Tool
    Jim
    Pickup
    Nov 2009
    Clarence,New York (western part near Buffalo)
    307
    I am new to the world of F-161 motors,I have one I want to put in a '52 wagon but the oil pan has the large(sump) on the front end and hits the 2 wheel drive front axle...so looking for the right oil pan if anyone can help...thanks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
