September 17th update. Its been awhile. The wagon now has 3780 miles on the clock since it went back into service. For the most part everything has been good. The generator started acting up so it was replaced with an alternator upgrade.
While it is no where as cool looking as a Mopar Alternator or a Generator it works and didn't require any system modifications to install with the stock harness. I did add a heavy guage battery cable from it to the positive terminal on the starter relay. 13.6 volts at idle, 14.5 volts rolling down the road. My lights are much brighter at idle.
The transmission has been grinding going into second regardless of clutch adjustment so I decided to pull the synchro out and take a look today.
Top off.
Transfer case and overdrive off. Shaft starting its way out.
Shaft out.
Synchro dog springs not installed correctly. If it matters. Both sides were this way.
Teeth movement on the brass synchros
One end of travel:
The other end:
First/reverse gear:
2nd gear - the bushing looks and feels like a new bushing.
So now I need to read up on all of this to figure out if my parts are worn. Everything else in the transmission looks really good. The reverse idler is snug on its shaft and the teeth look new. The cluster gear looks good. I just need to read up on this thing a bit.
Once this is complete I will be upgrading the engine oil filter to a Fram F4 housing I also found gl-4 gear oil in a variety of places - which is more brass friendly and Have a slew of axle and transfer case seals to install.
More to come. Does anybody else smell gear oil????
