TAO1
I put the wife's Honey-do-list on hold a couple weeks ago so I can finish my truck up.
I figure about mid-April at the latest.
I decided last November to swap out the front and rear original axles. Went searching and lucked out and found what I needed. Scrap, clean. grinding, order parts, wait for delivery etc.
The holidays and weather put a stop to truck work.
I've been busy as a beaver working on my truck for the last couple weeks.
After removing the original spring mounts and making new spring mounts they are bolted in place for now until I finish welding them in place.
The newer Dana 44 front axle is bolted in place with new U-bolts. Purchased new tie rod with drag rod. Looking good.
Oops, Problem with the pitman arm hitting the tie rod. Hmm. Remove the Power steering box and mounting bracket. Break out the angle grinder and attack the bracket that I had made last year.. Cut this, cut that. Figure a new mounting plan, okay, that only took 15 minutes to come up with the new plan.
Starting to look better that what I had before. Ordered a 30" long Double D steering shaft.
I don't own a shaft stretcher.
Need a different pitman arm, that is a little longer and will rise up 1.5 inches so that the drag arm will not be in harms way. I have a local shop digging for my needs.
I placed an order last December 20th, 2016 for a bolt on disk brake kit for the 9" rear axle.
I expected it would ship asap. WRONG. MFG is shipping to me. Guess what MFG said, "Closed for holidays and first 2 weeks of January for inventory". 3rd week of Jan. I'm told they are waiting for parts. UG!!!!!
Yesterday I got and email that it had shipped and it will be as long as 6 days from Calif. Dam, must be going via dog sled.
I can't post pictures as I have to figure out about resizing them. UG again.
Got to go for now.
Cheers, Thomas
Got to go for now.
Cheers, Thomas
