Likes Likes:  158
Page 17 of 20 FirstFirst ... 71516171819 ... LastLast
Results 161 to 170 of 192
Thread: Randy's 1950 Wagon Project
  1. #161
    Bigger Hammer RandyP's Avatar
    Randy
    1950
    Wagon
    Aug 2016
    Central Texas
    153
    I'm waiting on parts so I started working on my hood again. It has a sag in the middle that is about 1/4 inch low in the middle of the center riser. With a straight edge laying on the center of the hood it touches in the front and back but in the middle it is low. If I move the straight edge to the outside of the hood top it is level.
    Anyone else have this problem? If so, how did you resolve it?
    Thanks, Randy
  2. #162
    Well-Oiled Gojeep's Avatar
    Marcus
    1948
    Pickup
    Jan 2010
    Victoria Australia
    2,825
    Yes mine did that too if not worse. I show how I fixed it in my thread by standing on it!
    http://www.oldwillysforum.com/forum/...Project/page96
  3. #163
    Randy
    1950
    Wagon
    Aug 2016
    Central Texas
    153
    Thanks Marcus, looks like I will be taking the hood back to bare metal and trying your technique and see if I can get it back to the correct shape.
    Randy
  4. Likes Gojeep liked this post
  5. #164
    Marcus
    1948
    Pickup
    Jan 2010
    Victoria Australia
    2,825
    Quote Originally Posted by RandyP View Post
    Randy
    What I was hoping you would do rather than use more filler than needed. Specially on the hood which flexes a lot.
    If it doesn't work using your foot, you can also turn it upside down with the centre rib over a length of steel or hard timber, and use a wide brick layers bolster in the back side of the rib and hit it gently with a mallet working your way along. Start only where the worse of the bend is first before checking.
  6. Likes scramboleer, Bill Kuran, indian john liked this post
  7. #165
    Randy
    1950
    Wagon
    Aug 2016
    Central Texas
    153
    Quote Originally Posted by Gojeep View Post
    I would not have thought of that but it's probably what it will take to get the center rib back to where it should be so I can then raise the area beside it.
    I figured you had a good idea on how to resolve the issue.
    Thanks for your expertise!
    Sent from my SAMSUNG-SM-G891A using Tapatalk
  8. Likes scramboleer liked this post
  9. #166
    Randy
    1950
    Wagon
    Aug 2016
    Central Texas
    153
    I don't have a chisel that wide so I ground down a piece of scrap metal to match the shape of the hood riser channel. Tried laying the hood on a 2x4 but the wood absorbed all the force, so I laid the hood on the concrete and that did the trick. I started at one end and proceeded down the entire channel several times hitting it lightly checking the progress as I went. The center of the hood raised up 1/4" or so to be perfectly level. Still need to do some additional work on the rest of the hood to get it level. Have ordered a heat shrinking disk and plan to give that a try. Thanks again Marcus!
  10. #167
    Marcus
    1948
    Pickup
    Jan 2010
    Victoria Australia
    2,825
    Excellent and glad it worked for you mate.
  11. #168
    Randy
    1950
    Wagon
    Aug 2016
    Central Texas
    153
    Today I used a shrinking disk for the first time on my hood. The disk came with some instructions on how to use it, but stated that it is not a "magic tool." They lied. It is magic! With the paint removed on the top and bottom of the hood, I used the disk to raise and lower the metal on both sides until I got it back in shape. Having never used one before, I'm amazed at what you do by shrinking the metal! By using a hammer, my foot, and the shrinking disk, the hood looks pretty good. It will still need some filler, but only a skim coat to fill the imperfections. A week ago, I was ready to give up on the hood and see if I could locate a better one.
    Thanks for the help that this forum offers!!
  12. Likes Broken Wagon, Gojeep, commando_willys liked this post
  13. #169
    Randy
    1950
    Wagon
    Aug 2016
    Central Texas
    153
    Received some of the parts that I ordered, so I installed the front clip on the body so that I could install the brake booster, master cylinder and brake pedal assembly. I tried to get everything right, but with the booster mounted where I wanted it to go, the brake pedal was a little too short and too close to the gas pedal. The pedal has some adjustment on the mounting, but with it moved far to the driver's side, the mounting bolt and nut were visible and it was still a little too high. To resolve this issue, the brake arm needed to be lengthened and moved to the left about 3 inches so I made an extension out of aluminum first to get an idea and once I liked the position, one was made from steel and welded in. It's in a much better location now.
  14. Likes Broken Wagon, commando_willys liked this post
  15. #170
    Precision-Fit Broken Wagon's Avatar
    1960
    Wagon
    Apr 2015
    California
    834
