Willys pickup on S10 frame
crazyskinut
Mar 7, 2013
3
Canada
Tom
Hi there I'm new to this site and I call British Columbia, Canada my home. This site appears to have some knowable members and helful info. I recently obtained a 1952 Willys pickup 4wd drive. I have also purchased a 1991 Chevy S10 4x4 ext cab 5 speed pickup and am looking at the possibility of seting the willys body on an S10 4wd frame (118 in. wheel base)for beter brakeing, ride and more power. Any suggestions? And any picture if anyone has done this before would be greatly appreciated. Thanks Tom
dirtbuggy
Sep 29, 2010
571
new river az
Welcome and good luck with your new project. Lots of helpful folks in here and your plan sounds like a great one.
willys way
Feb 16, 2011
950
south central Pa
Tom
#3
Lots of work involved in that. Nothing interchanges so everything has to be arranged to work/fit. I tried this with a full size chevy years back and after a couple years of work and more money than I could afford the whole project went to the scrap yard. I now have alot more appreciation for the Willys Overland Company. Good luck.
5,766
#4
Welcome to the forum Tom-
scramboleer
Super Moderator
Aug 16, 2011
5,454
San Francisco, California
Dan
#5
Hi Tom,
Welcome to the forum. Sounds like you got a great project there. If the S10 frame swap is too complicated, another option would be to install the engine from the S10. Does it have the 4.3 V6? That swap is pretty common and doesn't overtax much of the Willys' chassis and drivetrain, although steering and stopping upgrades are also common.
Cheers,
Scramboleer (one of the many Dans)
Pivnic
Nov 24, 2009
3,897
Conifer, Colorado
John
Wagon, Pickup
#6
Welcome to the Forum Tom. There are others on this Forum that have done the S-10 Chassis Conversion with excellent results. I did a full sized Chevy Shortbed 4X4 Chassis Conversion under my 57 Willys Pickup. That project went quite smoothly. Check out my Build Log to see for yourself. http://www.cardomain.com/ride/3805815/1957-willys-pickup/
Check your State's Laws that may regulate that your tires can not stick out past your wheel wells, etc. That is not a problem in my great state of Colorado. Do your research and due diligence and make a plan. There are many successful Chassis Conversions done on these Old Willys Trucks, and if you do your homework and have a plan, your project will also be successful. Good Luck. Take lots of Pictures and create a Build Log for the Next Guy wanting to do this project! John (aka: Pivnic)
crazyskinut
Mar 7, 2013
3
Canada
Tom
Hi John
looked like an awesome project. You mentioned that there were other post of the s10 frame swaps. Where can I find them?
Pivnic
Nov 24, 2009
3,897
Conifer, Colorado
John
Wagon, Pickup
#8
Hi John
Hi Tom. I'd put out another post that you are looking for info from others that have done a Willys Pickup/S-10 Chassis Conversion. I know one Colorado member that did this exact project, but he may not sign onto the forum very often. You can PM him and see if he responds. His Forum Id is: nealneu He has a beautiful light Green Pickup with an S-10 chassis under it. It's quite a nice show truck. Let me know if you don't get a response and I'll try to get a hold of him for ya. Pivnic
cnsay
Jun 20, 2010
1,482
North Idaho
Chris
Welcome to the forums. Frame swaps can involve a lot of work, sometimes it can be easier to build a new frame to fit the components or to make mounts to fit the new components int the existing frame if it is in good shape.
crazyskinut
Mar 7, 2013
3
Canada
Tom
Thanks John, I sent an email off hopefully I get a reply.
The old frames not worth using, it's been too beat up. I have the tools and ability to do the swap I'm just looking for somebody who has done a simular project and knows what problem may occur and possible solution to fix them. The reasons I'm going with a modern frame and running gear is so that it can be a comfortable daily drive with good breaks and handling. And if any think ever goes wrong parts are easy to come by.
Thanks for all the interest guys :)
tjs68
May 23, 2011
82
Tom
Greetings ! I have considered the swap you are doing. I think it would be a great fit for a Willy's Pickup. The wheel base is correct, now the firewall to front axle distance is ? Check some of the build threads on here and see what you find !
Cannoncreek
May 23, 2014
1
Friday Harbor, WA
Court
#13
Newbie doing same swap
Hi John, I have a 4wd s10 118" frame from mid 80's and want to do the same frame for daily driver. Are you still doing your project? I a, in Friday Harbor, WA and just getting started, but noticed you are in BC. Where, and where to things sand?
